August 27, 2014, 11:34 |
Pneumatic silencer - How can I calculate it?
Roland Rakos
Rep Power: 17 |
Hello CFX users,
I would like to calculate a pneumatic silencer which inlcudes an outside plastic housing and a lot of very thin plastic fibers in the housing : http://www.arcek.com/dosya/urun/ARC-EXP.102379.jpg It can be calculated with porous domain, I think, but it is important for me to consider the very small pressure fluctuations coming from the pneumatic system. The pressure signal will transform to a spectrum finally. In my opinion, the porous domain is not correct solution because it will damp the small pressure fluctuations significantly which will result incorrect spectrum of course. Have anybody an idea to solve this problem? At the moment I think, there is one way to solve the problem exactly: calculate the silencer geometry in 1:1, without simplifications... Thanks a lot Roland |
August 27, 2014, 18:43 |
#2 | |
Rep Power: 143 |
I cannot see that link.
You comment is puzzling: Quote:
Rather than doing this by gut feel, how about you actually work out what is going on. Work out what dissipation acoustic pressure waves will have in the device - this will depend on whether it is a separation or shear based dissipation. Then you should have an idea what pressure loss function is appropriate. Then if the porous model is using that pressure loss function then the porous model is appropriate; if you cannot apply that pressure loss function then the porous approach is inappropriate. |
How to calculate grid width in control volume | Ingenierias2003 | OpenFOAM | 5 | November 24, 2010 12:40 |
calculate values for eps and k from Re or u????? | sbar | OpenFOAM Pre-Processing | 5 | August 16, 2010 04:10 |
How to calculate Torque for francis turbine | manish | CFX | 4 | March 15, 2007 02:57 |
Pneumatic conveying drier with CFX | muslikhin hidayat | CFX | 0 | August 30, 2000 02:51 |
How to calculate density of solid phase | zhou | Main CFD Forum | 0 | December 17, 1999 19:06 |
