CFD-post: defining (or projecting) point on surface
Old   March 31, 2015, 13:01
Default CFD-post: defining (or projecting) point on surface
NC
bongbang is on a distinguished road
I'm making a time-series chart of wall shear stress at a point. I added the point using XYZ method and pointing the mouse at the location I wanted. I even looked at the point from different views to convince myself that it is where I think it is. When I turn on the chart, however, there is no WSS data associated with the point, which means the point is not on the wall (or, to be precise, the nearest node to the point is not on the wall). How can I define a point in such a way that ensures it's one the wall.
PS I tried defining the point so that is behind the wall (outside the fluid domain) in hope that the nearest node would be on the wall, but that didn't work either.
bongbang is offline   Reply With Quote
Old   April 1, 2015, 12:16
NC
Problem solved. It wasn't what I thought it was, and defining a point on the wall is as easy as it should be.
cfd
Parallel process & CFD POST jypark FLUENT 2 August 14, 2013 23:49
CEL mathematical functions in CFD Post Jonathan CFX 9 November 5, 2012 08:37
Internal CFD on a surface model (SW2010) sw1990 Main CFD Forum 7 January 4, 2011 19:36
Poly lines in CFD Post ashtonJ CFX 0 December 2, 2010 02:46
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
