September 28, 2014, 05:57 |
wall Y plus
tahir
Rep Power: 16 |
I am doing external CFD on irregular body. I have to solve Mach number above 1 and less than 1. I am confuse in wall Y plus. what value should i achieve for subsonic and supersonic flow. can anybody guide me
September 28, 2014, 06:14 |
Rep Power: 143 |
Subsonic/supersonic is irrelevant for y+ selection. What is important is whether you need to resolve down to the viscous sublayer or not.
September 28, 2014, 06:38 |
tahir
Rep Power: 16 |
Thanks for reply. Glenn if i resolve the viscous sublayer then will i get my results more accurate
September 29, 2014, 06:25 |
Rep Power: 143 |
What results are you trying to get?
September 29, 2014, 10:17 |
tahir
Rep Power: 16 |
gelnn in first phase i will find Cd, Cl and pitching moment coefficient. Then in second phase i will find rolling coefficient
October 5, 2014, 07:43 |
Rep Power: 143 |
It depends on what you are modelling. This conversation is becoming circular.
I would recommend reading a text book on turbulence modelling, such as "Turbulence Modelling for CFD" by Wilcox. You really need a bit of background in these areas so you can understand the implications of your modelling choices. |
Thin Wall Heat Transfer BC for rhoSimpleFoam | swahono | OpenFOAM Running, Solving & CFD | 12 | October 4, 2013 11:49 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
Patches for OpenFOAM 1.7 on MacOS X | gschaider | OpenFOAM Installation | 101 | September 21, 2011 05:37 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
Quick Question - Wall Function | D.Tandra | Main CFD Forum | 2 | March 16, 2004 04:29 |
