October 12, 2014, 18:42 |
Post Processing Tetrahedral mesh
Ali Madayen
Rep Power: 12 |
Hi everyone
I'm studying a very complex geometry which I cannot generate structured mesh for it. Hence, I used ICEM to mesh it with commonly tetrahedral elements (more than 90%) Checking the grid independency with number of the elements varying from 300K to 1000K, results are independent from the mesh. But the problem is, the chart that I draw for checking independency is not smooth, I've uploaded an image of it. Is this due to poor mesh quality, or it is an intrinsic characteristic of the unstructured meshes? I should mention that the solution is well converged (Residuals 1e-5 and imbalance 1e-3. Is there a way to make these graphs smooth? I have not worked with unstructured grids that much so sadly i'm not familiar with them Best Ali |
October 12, 2014, 19:05 |
Rep Power: 143 |
Firstly - a mesh sensitivity sweep from 300k to 1M nodes is unlikely to be wide enough to capture anything useful. The parameter you should be sweeping is the element edge length. So a halving of the element edge length will result in approximately 2^3 = 8 times the number of nodes.
Your graph shows a parameter which should be smoothish but looks bumpy. You are correct in saying: * Yes, this can be due to poor mesh quality. * Yes, unstructured meshes frequently do this. But mesh refinement should smooth it out more and reduce the wobblyness. |
October 13, 2014, 06:59 |
Ali Madayen
Rep Power: 12 |
Thanks for your help.
I've checked the 2.2M grid but the problem still exists. I've extracted geometry from CT angio imaging by Mimics software, and I doubt smoothness of the surface. I plotted velocity in cross section for various meshes and they were identical. Is this parameters for the mesh acceptable? I couldn't find any suitable range for edge-length ratio, but for face angle values more than 10 is said to be acceptable. 60<Face Angle<160 1<Edge Length Ratio<13 Connectivity number: 2-42 volume ratio: 1-125 (I guess high volume ratio is due to the coarse-mesh entrance volume that i've placed in the inlet for having fully developed flow at the main volume inlet) I would appreciate if you could comment on these parameters. |
October 13, 2014, 07:02 |
Rep Power: 143 |
Before considering any of the issues you discuss, have a look at the geometry you are modelling? How smooth is it? If it is rough - especially with roughness of the same length scale as your mesh - then no matter what you do you are going to get a lumpy results curve.
October 13, 2014, 07:11 |
Ali Madayen
Rep Power: 12 |
I could plot this. X coordinate on the surface polyline.
I guess for a grid element size of 2.1e-4 these oscillations are not suitable. Is there any better way to determine the smoothness? |
October 13, 2014, 17:24 |
Rep Power: 143 |
I have no idea what that graph is showing. You would have to show an image of your geometry for that to make sense.
Have a look at the wall boundary facets. Is the wall being resolved as a smooth curve, or does each facet have its own angle? |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
