cylindrical coordinate
Like Tree3Likes
  • 1 Post By Thomas MADELEINE
Old   October 22, 2014, 04:46
Default cylindrical coordinate
papamichous is on a distinguished road
How can I use cylindrical coordinates in ANSYS CFX?
papamichous is offline   Reply With Quote
Old   October 22, 2014, 05:33
Thomas MADELEINE
Thomas MADELEINE is on a distinguished road
your question is quite large...
When you have defined your axis you can access to the radius and theta variables.
See any tutorial in turbomachinery (tuto #14 for instance) to have an example.
papamichous likes this.
Thomas MADELEINE is offline   Reply With Quote
Old   October 22, 2014, 09:02
i want simulate this case of water flow through a porous media
Old   October 22, 2014, 10:30
Thomas MADELEINE
So if you want to simulate without the standpipes you have a rotationnal symmetry.
So you can define only a part of the domain (1/6 => 60° for instance) and use the axis to define your symmetry. You will have a radius variable in CFX Pre.
In the case you want to keep your standpipes (it can affect the flow), you don't have any symmetry so you wille have to define the whole domain and I don't know how create an axis...
In this case I will probably use a very ugly method by create my own radius expression...
for instance if you axis is z:
Radius = sqrt((x-x0)²+(y-y0)²)
Theta = atan(y/x)*step(x)+(atan(y/x)+180)*step(-x)
or something equivalent
Old   October 22, 2014, 11:46
can you create the geometry for me for both?
Old   October 23, 2014, 04:18
Thomas MADELEINE
I am sorry but I can't create the geometry...
But I don't think it is really complex... you can create a cylinder a cut it into three pieces...
Then for the one with standpipe:
you add two small cylinders.
For the symmetric one:
you cut every thing by an angle of your choice (45° or 60° sounds correct to me)
Normally any 3D CAD software can handle it
Old   October 23, 2014, 09:33
how can I represent the shear stress between the fluid medium and the porous medium?
Roe Flux Difference Splitting Scheme in Cylindrical Coordinate System _inferno_ Main CFD Forum 0 November 8, 2013 04:10
cylindrical coordinate vs cartesian coordinate Lam FLUENT 10 May 11, 2013 13:05
cylindrical coordinate -Gambit noussa ANSYS Meshing & Geometry 2 June 12, 2010 09:07
CFD Software with Cylindrical and Spherical Coordinate cfd2010 Main CFD Forum 0 June 9, 2010 21:55
Cording Ground.for in Cylindrical coordinate J.H. Lee. Phoenics 2 March 28, 2003 04:28
