February 20, 2015, 00:50 |
Basic Melting simulation
Sivaramakrishnan
Hey everyone.
I am a newbie in CFD as well as ANSYS CFX. I am trying to understand hoe to apply boundary conditions and simulating flows. Now, I am working on a simple simulation where an ice cube is placed on a tray. It is in vacuum because i don't want to complicate stuff by adding another fluid here. I am done with the geometry and meshing. I want to achieve the following result. The heat transfers from the tray(25 deg C) at 100 W/m2 The ice cube at (-5 deg C) absorbs this heat and melts. I actually want to see the "ice melt" and form a liqiud with free surface. How should I proceed. Thanks in advance |
February 20, 2015, 05:18 |
Rep Power: 143 |
If you are new to CFD then a multiphase model with phase change is not the place to start. Your model is probably 3 phase actually - solid, liquid and gas - so definitely no for beginners. CFX does not have a built in model for melting or solidification so if you want to model it you have to generate the model yourself. CFX does have the flexibility to do this, but it is recommended for advanced users only.
You may not need to model the melting process. You could just generate liquid water at the melting interface - this would model the accumulation of liquid water. This model is still a multiphase free surface model so is not simple, but at least is more likely to be achievable for somebody new to CFD. |
February 22, 2015, 08:02 |
Mr CFD
I laughed at the title. There is nothing basic about modelling what you want.
It is an absolutely difficult task to do - especially under a vacuum which many CFD solvers will fail to handle (a perfect vacuum does not exist). Start at 1 bar pressure, and ramp the pressure down slowly. As you get to 100mbar and lower you'll begin to run to convergence difficulties (as if phase change isn't difficult enough as it is). I suspect this project will take a long time for a newbie to CFD. What information do you want CFD to provide to you? |
cfx 14.5, equilibrium phase change, melting ice, vof phase change |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 04:44 |
Requiring some help regarding tornado simulation | amarjogot | Main CFD Forum | 0 | June 20, 2013 12:26 |
ice melting simulation | pratikmehta | ANSYS | 3 | April 17, 2013 09:52 |
Ice melting Simulation | pratikmehta | CFX | 13 | February 29, 2012 21:14 |
Basic Poiseuille flow simulation question | Ashish | Main CFD Forum | 0 | October 2, 2007 13:05 |
