Different results in CFX with the same configuration on same airfoils made in solidwo |
April 18, 2015, 02:59 |
#21 | |
Darius Geric
Rep Power: 11 |
April 18, 2015, 03:59 |
#22 | ||
Alex
Rep Power: 46 |
That does not really answer my question. Quote:
We need a screenshot, another mobile phone photo wont help. |
April 18, 2015, 04:08 |
#23 |
Darius Geric
Rep Power: 11 |
Sorry I don't get your question... I've got two but the same airfoils, one has been rotated 20 degrees in solidworks and the other one was used the expression to apply the AOA.... I've uploaded the domain picture and the both domains are just the same so I don't get what you mean by how the expression alters the geometry
April 18, 2015, 05:14 |
#24 |
Alex
Rep Power: 46 |
Let me recapitulate what I understood: You have two DIFFERENT geometries.
In geometry 1, the airfoil is rotated by 20 degrees around the z-axis. The flow direction at the inlet is in x-direction so the angle of attack of the flow is actually 20 degrees. You evaluate lift and drag forces in Y- and X-direction respectively. I agree with this setup. In geometry 2, the airfoil in not rotated. If the flow enters in X-direction, there is actually 0 angle of attack. Even if you account for an angle of attack by changing the inflow direction, the flow will be straightened by the side walls and the airfoil will not "see" the AoA you entered at the inlet. It seems to me that all you did was changing the vectors of force evaluation. So from what I understood so far, your two computational setups do not represent the same physical setup. |
April 18, 2015, 06:00 |
#25 | |
Darius Geric
Rep Power: 11 |
You got it right for the first part. I didn’t claim that the AOA for the non-rotated model has not been accounted or applied in the simulation. Its results are different to the zero AOA but very different to the first one. The AOA has been defined by the expression, and everything else such as the mesh, domain, inlet and outlet pressare and etc.. are just the same so I expect to get the same results. The only difference is that one AOA was made in solidworks and the other one was accounted by expression the rest are all the same... that's all. I don't know what you mean by "the flow will be straightened by the side walls" |
April 18, 2015, 07:00 |
#26 |
Alex
Rep Power: 46 |
Leaving aside expressions for force evaluation for a moment:
Are the two setups identical in terms of geometry and boundary conditions? |
April 18, 2015, 07:16 |
#27 | |
Darius Geric
Rep Power: 11 |
I accidentally discovered that these two models are giving different results cuz I couldn't get the similar results as the wind tunnel test I made earlier in the university's lab. So I wanted to try different way and I got surprised that I get different values. The lift on the rotated model simulation gave 52N while the non-rotated model gave 21N and the wind tunnel gave 98N. That's why I got so confused. I tried to get the result by much simpler softwares like Designfoil and javafoil and their results were very closer to the wind tunnel test data than the CFX... I also tried to simulate it with fluent but I still got the similar results as the CFX. |
April 19, 2015, 06:30 |
#28 |
Rep Power: 143 |
I have deleted a number of posts from this thread as the discussion went off-topic.
Please ensure that all future posts on this thread remain on topic. |
April 20, 2015, 08:45 |
#29 |
Edmund Singer P.E.
Rep Power: 20 |
You guys are wasting time trying to come up with a solution on why the solutions dont match each other, and why they dont match wind tunnel.
Glenn answered your question in detail, your mesh is crap. Fix that and you will get better results. If you are just calling this into Ansys mesh in WB, setting a few sizes and hit the mesh button, you are going to get a terrible mesh, like what you have shown. You need to control the inflation rate, the expansion rate and the size on the surface. |
Time average results in Transient CFX Simulation | BalanceChen | CFX | 32 | September 30, 2021 13:59 |
Plotting graphs from multiple results into one graph in cfx results | ejdrlqja | CFX | 3 | April 10, 2015 03:41 |
CFX and Fluent: same BC, same model but different results! Why? | Zzmon | CFX | 6 | February 23, 2015 10:31 |
CFX POST results | phaninder | CFX | 1 | August 1, 2014 06:14 |
CFX 5.5 results export | N Menon | CFX | 1 | January 3, 2002 20:53 |
