May 6, 2015, 11:30 |
Initialization visualization
Rep Power: 11 |
How can I see fields (velocity, pressure, turbulent viscosity, ...) of Automatic Initialization in CFX ? Thank you |
May 6, 2015, 12:21 |
Rep Power: 32 |
Start the run, and write a backup file before the first iteration.
Check for how to setup backup files, and any subtleties at the start of the run. |
May 6, 2015, 17:47 |
Rep Power: 11 |
Thank you very much, I found it
However, there is something that I don't understand. When I look at eddy viscosity contours at inlet with the integrated variable ''Eddy Viscosity'' of CFX, I don't see the same thing that when I create a variable with the integrated variable ''Eddy Viscosity'' .... In fact, the integrated variable of CFX use k and epsilon to define and the variable that I have created use the initial parameter that says , do you know what I mean ? |
FMG initialization query | Mohsin | FLUENT | 6 | November 2, 2016 02:02 |
CFX temperature initialization | jp_ | CFX | 3 | August 28, 2014 09:06 |
Visualization of higher order solution | shyamdsundar | Main CFD Forum | 1 | July 23, 2010 03:55 |
compressor initialization | paglia | FLUENT | 0 | February 1, 2006 15:14 |
Flow Visualization of impinging swirling flow on the wall. | sangaria | Main CFD Forum | 2 | March 26, 1999 13:31 |
