CPU-time and routines
Old   May 28, 2015, 09:20
Default CPU-time and routines
boubou is on a distinguished road
I use fortran routine in CFX but
Does a calculation using routines is longer than a calculation without routine (in terms of CPU-time) ?
If yes, which statements consume time ?
Thanks
boubou is offline   Reply With Quote
Old   May 28, 2015, 09:48
Opaque will become famous soon enough
Not sure what your concern is. The software package is a collection of hundreds/thousands of routines/functions; therefore, it should be no different.
Now, if you add your own routine/function to customize something it should be nearly the same time unless your algorithm is either better (less time), or worse (a lot more time) than the internal algorithm.
Summary: if you use your own, you may be partially to blame for slow down, or congratulate if it speeds up. Otherwise, it is the provider to blame for lack of performance.
Opaque is offline   Reply With Quote
Old   May 28, 2015, 10:25
Thanks for your reply. But is it sure that the simple fact to add a Junction Box Routine slow down the calculation ?
Old   May 28, 2015, 15:31
That depends on what you do in it.
If you do nothing, it means nothing compared to the calculation time.
If you create an infinite loop, you get the idea.
Total time for simulation Meerkat Main CFD Forum 1 September 5, 2011 07:17
old value Martin Schmidt CFX 7 December 20, 2005 18:50
