June 3, 2015, 02:17 |
Simulation of a De Laval Nozzle
Rep Power: 10 |
Hello there!
I am pretty new to this forum and to ANSYS CFX, and I've been trying to simulate the flow of air through a De Laval Nozzle with a subsonic inlet and a supersonic outlet. I have scrummaged through some of the threads on the De Laval Nozzle here, but I couldn't really find anything on what I am having trouble with. Anyway, these are my inlet and outlet parameters: Fluid Model : Total Energy with Shear Stress Transport Inlet : Subsonic Mass flow at the inlet : 0.69 kg/s (This is the only inlet parameter that is available) Material : Air at 650 degree C (I am not sure if I have to enter this as the value of the Static Temperature or the Total Temperature at the inlet, since there is a dialog box for Static/Total Temperature, or whether I should enter this at all) Outlet : Supersonic (Velocity > 550 m/s) I tried setting the outlet flow type to 'Supersonic' with a monitor point near the outler region, but when I do the solution, I seem to get really wrong velocity values like 0.5-0.6 m/s at the monitor point. I don't really know what I am doing wrong here. This is the nozzle I have sketched. http://postimg.org/image/xivgcgsph/ |
June 3, 2015, 06:20 |
Thomas MADELEINE
Rep Power: 11 |
CFX ask you the temperature of your Inlet since you have enter a energy equation (total energy whit shear stress transport). If all your walls are adiabatic (usual for turbomachinery), and there is no big change of energy you can disable it.
But here since you are transonic, i will keep the energy equation (this is only my point of view). what is the boundary condition you use for the outlet (is it velocity outlet ?) Is the material air with constant density or air ideal gas with inlet at 650°C ? if it is velocity, then the solver doesn't have a pressure reference. the basic couple of inlet/outlet conditions are : Total Pressure / Pressure Velocity / Pressure MassFlow / Pressure Moreover I personally avoid using massFlow of Velocity in a blocked nozzle because you are at the point the massFlow is limited at the col (M=1). you can approximate the theoretical maximal massFlow of a nozzle by this formula : Q = AreaCol x PstatAval x (gamma / R / TempAval)^0.5 x (2 / (gamma + 1))^((gamma + 1)/2/(gamma - 1)) (sorry for the long formula) |
Laval Nozzle sonicFoam inlet and outlet bc | BernhardGrieser | OpenFOAM Running, Solving & CFD | 10 | February 16, 2017 07:45 |
supersonic (Laval) nozzle, unphysical Mach number | Judith | CFX | 7 | August 14, 2014 18:28 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 16:06 |
Nozzle - Simulation converges, but data incorrect | fade | CFX | 0 | July 20, 2009 04:13 |
Need assistance in BC's for simulation of Vacuum cleaning nozzle | bruce | OpenFOAM Running, Solving & CFD | 0 | May 22, 2009 13:56 |
