jump of residual in transient sim
Old   June 26, 2015, 06:42
Default jump of residual in transient sim
Andreas
Flashidashi is on a distinguished road
Hey guys,
i noticed a quite interesting residual-phenomenon in my results. In this case i simulated the flow around a vertical cylinder (transient).
What i mean is the jump in picture (b) after 500 iterations.
Anyone knows, which effect(s) is/are responsible for it?
Maybe Ghorrocks?
Thanks in Advance Flashi
Flashidashi is offline   Reply With Quote
Old   June 26, 2015, 07:02
If this is a transient simulation it is probably doing an additional coeff loop per time step to achieve the convergence tolerance.
By the way: reporting convergence tolerances like this is a bit pointless for transient simulations. You need to establish a suitable convergence tolerance and just do as many coeff loops as is required to make it. This means that your residuals should be flat from beginning to end as it just achieves the tolerance. It will take more coeff loops in the tricky to converge bits and less in the easy bits, but the residual it achieves in the end is roughly the same from beginning to end of the simulation.
Old   June 26, 2015, 08:28
Andreas
For these simulations i used 2 to 6 inner coef. loops and a residual of 1*10^-(4) for the global mesh (with Courant_max = 1) and initial files from steady state sims. So i got these residuals for the finer mesh-regions. After a certain number of iterations, only 2-3 coef. loops were neccessary. So i think, i did what you say in your post.
Greets Flashi
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
