August 19, 2015, 03:30 |
Domain independent test
ganesh chakravarthi
Rep Power: 12 |
Hii everyone,
Presently I am doing problem on fluid flow analysis.. In my problem I have taken car as my model.. I have small doubt in order to create fluid flow region I.e,domain.. I mean on what basis I have to create my domain- is this based on length and size of my model or anything else?? Is there anything word like this DOMAIN INDEPENDENT TEST..if yes what is the use of it..please help me.. |
August 19, 2015, 05:51 |
Rep Power: 143 |
Yes, an important check for a CFD model is that your boundaries are sufficiently far away (assuming you are trying to model a far-field condition) to not significantly affect results. Performing a sensitivity analysis on boundary condition proximity is a really good idea.
I also recommend reading the literature as published CFD models should specify how big a domain they used - this can give you a guide. But be careful that different CFD methods require different boundary proximities, and some authors may accept a different amount of boundary proximity induced error than you can. |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Grid independent test | naruto5255 | FLUENT | 0 | June 23, 2015 08:39 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
