August 24, 2015, 13:53 |
Negative torque_z()@blade
Alex
Rep Power: 10 |
Good evening, help please. I am doing flow around the blade. With increasing rev/min^-1, torque_z()@blade becomes negative.
What is my fault? Tried to swap the axis -- no results When rev/min^-1, = 91 (λ = 4) -- all is well with rev/min^-1, = 137 (λ = 5) torque_z becomes negative |
August 24, 2015, 18:16 |
Rep Power: 143 |
Have a think about what this means. If the torque is negative then the rotor will slow down. This means you have exceeded the speed of the rotor.
That assumes your simulation is accurate. Your simulation could also be inaccurate - that is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
August 26, 2015, 09:57 |
Alex
Rep Power: 10 |
Thank you very much for your answer.I will try to understand.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
