subdomain that is just a portion of its parent |
August 29, 2015, 09:13 |
hani mortezaee
Rep Power: 11 |
dear cfx users
i want to have subdomain that is not consist a whole domain what should i do ? obviously i need to model another volume in my geometry , i did that now in cfx-pre when i defined my domain to have all the bodies and then i defined my subdomain that is just a portion of my parent domain , i had an error regarding the isolated fluid , so i changed this solver check in expert parameters to false , it did converged then , but when i saw the results it appears that the domains dont have any physical connection i mean that my subdomain that is energy source does not interact with its parent domain, so what should i do ? thank you all in advance |
August 30, 2015, 06:18 |
hani mortezaee
Rep Power: 11 |
no need to help its solved ,
August 31, 2015, 05:40 |
pkladisios
Rep Power: 10 |
Out of plain curiosity, how did you manage a subdomain that's only a portion of it's parent? I wasn't aware that was possible.
August 31, 2015, 06:05 |
Rep Power: 143 |
When you define the domain include 2 or more mesh regions in it. You can then define a subdomain consisting of some or all of the mesh regions. If it is only some of it the subdomain will cover a portion of the parent domain.
August 31, 2015, 06:23 |
pkladisios
Rep Power: 10 |
Thank you, Glenn. So, if i understood correctly, this has to be done beforehand, during meshing. Creating various mesh regions allows me to select sub-subdomains ?
August 31, 2015, 06:58 |
Rep Power: 143 |
Yes, the mesh regions are defined in the meshing package.
August 31, 2015, 08:56 |
hani mortezaee
Rep Power: 11 |
i create couple more regions in my geometry and then i selected all of them and rmb and "Form new part" , by this i have just one part but i got all of the volumes i need to use in my model in cfx-pre ,its really good way to define sources in the domain
August 31, 2015, 10:19 |
pkladisios
Rep Power: 10 |
I thank both of you. Useful tip!
Error messages | atg | enGrid | 7 | August 30, 2013 11:16 |
two subdomain in fluid domain does not word (CFX) | maxwellandi | CFX | 4 | November 28, 2012 15:45 |
Flow with multiphase reactions: parent and child material | Antanas | CFX | 0 | February 13, 2012 03:15 |
Subdomain or Interfaces (CHT) | sandeep_tu | CFX | 8 | July 14, 2009 11:06 |
set temperature on subdomain, in transient mode | nicolas | CFX | 0 | August 16, 2006 06:42 |
