how to make an addtional variable or expression to get erosion rate |
October 14, 2015, 05:31 |
Bruce Xiao
Rep Power: 11 |
Hi! Everybody
I want to get the mass erosion rate of pipe. The mass erosion rae is defined as the mass loss of pipe per unit mass of impacting particles. Mass erosion rate=change in mass of wall(pipe)/mass of impacting particles units: [mg/g] In CFX-Post, how to define an additional variable or expression to get it? Thanks! |
October 14, 2015, 11:15 |
Rep Power: 11 |
Hi
Not sure about what you are looking for, but if you run a simulation using an erosion model under output variables, for particles, you should be able to find particle.Erosion Rate Density [kg/s/m^2] and this should be a (qualitative!) index of the erosion. I suppose that from the Erosion Rate Density available in CFX you should be able to get your variable. See also in the Theory Guide the Section 6.4.3 Overall Erosion Rate and Erosion Output. Cheers |
October 14, 2015, 23:41 |
#3 | |
Bruce Xiao
Rep Power: 11 |
October 15, 2015, 03:58 |
Rep Power: 11 |
If I well remember, the particle mass flow rate impacting on a wall can be obtained using the massflow function for the particles over a named selection.
erosion rare particle |
Use expression instead of variable | Anna Tian | CFX | 2 | December 4, 2012 18:36 |
Additional variable as output of an expression | Chander | CFX | 1 | November 22, 2011 12:54 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
Relief Plots in CFX | Michael | CFX | 15 | June 30, 2006 08:01 |
