Are existing source terms in CFX linearized (for example buoyancy, cavitation models) |
November 3, 2015, 07:50 |
Mr CFD
Rep Power: 14 |
Hi
Are existing source terms in CFX linearized (for example buoyancy, cavitation models)? As in, are the linearization coefficients already taken into consideration? |
November 3, 2015, 17:25 |
Rep Power: 143 |
Some yes, some no. I know the surface tension one is not very well linearised and that is why surface tension slows CFX down so much. But most of the rest are well linearised.
A crude way to tell is to run a model with and without the model and see how much it slows down. If convergence is much slower then the linearisation is probably not too good. |
November 4, 2015, 03:29 |
Mr CFD
Rep Power: 14 |
Thank you
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
add source terms in CFX | radouane_bne | CFX | 3 | April 12, 2013 08:45 |
source terms and mixing in CFX | Timothy Pau | CFX | 3 | August 9, 2000 06:11 |
