May 26, 2016, 07:02 |
Nitrogen Sparging in Olive Oil
Simone Spanu
Hi to everybody.
I have to simulate a porous sparger used to insufflate Nitrogen in a Olive Oil flow. A simplified geometry of the system is attached. Boundary conditions on Inlets, Outlet and Walls are the following: In_Oil: Mass Flow Rate = 1.28 kg/s In_N2: Mass Flow Rate = 3.9e-04 kg/s Out: Opening Condition with Relative Pressure = 71000 Pa Walls: Fluid Dependent; for Nitrogen Free Slip Wall and for Olive Oil No Slip Wall. The sparger has been modeled using a porous domain. For Nitrogen has been set an Isotropic Loss Model (Loss Velocity Tipe: Superficial) based on Permeability and Loss Coefficient. These two parameters have calculated using the following equations: Permeability = [(Dp^2)*(epsilon^3)/[150*(1-epsilon)^2] Loss Coefficient = 2*[1.75*(1-epsilon)/(Dp*(epsilon^3)] Where epsilon is the Volume Porosity (set to 0.7) and Dp is the diameter of the Nitrogen particle (set to 40 μm, which is the diameter of the holes located on the sparger). For the Olive Oil has not been set a Loss Model. The adopted turbulence model is k-e and there is no heat exchange (Isothermal Model, Temperature fixed at 25°C). In the multiphase settings has not been set the homogeneous model. The analysis is stationary and a physical timescale of 0.5e-03 is adopted. The problem is that, after a certain number of iterations, the volume inside the porous media is partially filled by Olive Oil, thus obstructing Nitrogen flow. If I try to insert a Loss Model also for Oil (setting a very low permeability in order to avoid that Oil goes inside the sparger) the simulation crashes after a few iteration (Overflow). Any suggestions? Thanks in advance. |
Phase change material in oil pan - solidification | wsh | FLUENT | 7 | August 14, 2015 06:50 |
[General] Plot the spreading of oil on the surface of water over time | liguifan | ParaView | 11 | February 2, 2014 07:51 |
oil & water - dynamic contact angle | manxu | Fluent Multiphase | 3 | October 17, 2013 06:51 |
dynamic contact angle - oil & water | manxu | Fluent UDF and Scheme Programming | 0 | October 16, 2013 02:31 |
oil aeration problem | wprostaff | FLUENT | 0 | July 19, 2011 15:41 |
