local coordinate frame (axis of rotation), moves in a straight line too |
February 8, 2016, 00:32 |
dyson ilia
Rep Power: 10 |
Hello
in cfx, rigid body: how can i define local coordinate frame (axis of rotation) that in transient run, moves in a straight line too. I would like to rotate my subdomain with deforming mesh. This is OK. But this domain moves in a straight line too. Rotation of the body is based on the original X-Y-Z coordinate frame but of course it should move with the body together. Can i define moving coordinate frame that is local and attached to the my rigid body ? Regards Dyson ilia. Last edited by dyson; February 29, 2016 at 03:11. Reason: attach file |
February 10, 2016, 03:23 |
Description
dyson ilia
Rep Power: 10 |
in cfx-pre coordinate frame setting, how i define local coordinate frame on boat surface that moves with my boat?
February 10, 2016, 06:02 |
Rep Power: 143 |
I don't think the motion you describe is supported, so you will have to use moving mesh to do it.
But why do you need to do this at all? Why can't the helicopter body be stationary, the blades simply rotate, and the surrounding air can flow past it with an inlet/outlet? |
February 10, 2016, 07:30 |
Edit pic and update post(redefine proplem)
dyson ilia
Rep Power: 10 |
thanks a lot.
- problem : simulation of "self propulsion test of boat". - two domain : main and trs(transient rotor domain-with 3 blade propeller) - boat is defined as a rigid body.freedom: vertically and rotate about axis normal to plan axis) {attached pic} - shaft and trs interfaces , wall motions setting: rigid body - flow from inlet to outlet (horz) - in transient run,boat move up by hydrodynamcis effect of hull, then axis of rotation of propeller must be move with boat vertically, is it possible ? - in my runs shaft and propeller moves with rigid body but axis of rotation is the same stationary axis that define in cfx-pre setting, as a result the gap occur between propeller and boat. because propeller axis rotation isnot correct axis. ***- in cfx-pre coordinate frame setting, how i define local coordinate frame on boat surface that moves with my boat. |
February 10, 2016, 17:38 |
Rep Power: 143 |
This is going to be a very hard simulation to do.
It is MUCH easier if you separate the simulation into two: * One simulation where you do the propeller by itself and get its performance curve. This is just a standard rotating frames of reference turbo machine simulation. * A second simulation where you do the rigid body simulation of the boat, but you model the propeller as a force acting on the hull and a momentum source to generate the flow - but you do not actually model the prop, just its performance curve from the first simulation. |
February 13, 2016, 05:00 |
re
dyson ilia
Rep Power: 10 |
thanks a lot 4 your reply Glenn.
in general, in cfx-pre coordinate frame setting, how i define local coordinate frame on(rigid body) boat surface that moves with my boat? |
February 13, 2016, 05:03 |
Rep Power: 143 |
I do not know, I am not familiar with that area of the software. I don't even know if it can be done.
February 13, 2016, 05:09 |
re
dyson ilia
Rep Power: 10 |
OK Glenn, thanks
no any body 4 reply? Last edited by dyson; February 17, 2016 at 03:24. |
April 26, 2016, 07:06 |
no body ?!
#9 |
dyson ilia
Rep Power: 10 |
friends; any one for reply?!
April 26, 2016, 21:47 |
#10 |
Rep Power: 143 |
Why don't you just try it and see if it can be done?
May 24, 2016, 06:42 |
do it together
#11 |
armin najarian
Rep Power: 10 |
i have the same problem.
i dont know how to define a coord that move with a rigid body. but i think there is a way with using expressions. i am working on it. if i can move the coordinate with the rigid body so we can rotate the coordinate frame with a constant angular vel. u can send me an email to share our informations faster. armin.najarian@gmail.com |
moving coordinate frame, rigid body |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger | benru | OpenFOAM Meshing & Mesh Conversion | 3 | June 29, 2008 21:24 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
