write a .def file in CFX-pre from the Command line |
April 28, 2016, 08:11 |
Rep Power: 10 |
Hello my dear friends,
I intend to write a definition file(input) in CFXpre for the cfx5. solver using the command line from a mesh .gtm and a .ccl file Now i found this post in the internet > http://www.eureka.im/3852.html but it doesnt really help me. Would also help me if you had some advice generally where to seek info about working throug command-line(for cfx.solver prette good explanation in the documentation but for CFXpre coudnt find something comparable) I am a real newby in CFX, would be very thanfull for any help!) |
April 28, 2016, 08:44 |
Rep Power: 10 |
If you are a real newby as you say, wouldn't it be better to start making a a def file from CFXpre? Import your mesh and ccl then click on the button that says, write definition file. Why do you want to write it from the command line?
April 28, 2016, 08:49 |
Rep Power: 10 |
well ok) my be the definition "newby" is to hard.
i already can set up my simulation from the GUI and got the results i needed. Now for my working pupose it is nessesary to do all this work whit a "skript" using the command line in order the to integrate it in a larger simulation circuit. Thank you!) |
April 28, 2016, 08:59 |
Lance
Rep Power: 22 |
Either
Record a session file in cfxpre and look at the output. Then run cfx5pre -batch mysessionfile.pre or Check the manual for whatever command line syntax you need. |
April 28, 2016, 11:26 |
Rep Power: 10 |
Thank you very much!. Helped me exactly as i was hoping! Have a nice day)
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
