October 24, 2016, 05:22 |
High Speed Compressible Flow through a valve
SAM
1. If P-Mass imbalance varies between 1% can I conclude that the solution is converged.
2. One of momentum linear solution got small ok...what should I do to avoid it? 3. I created a plane in the upstream and downstream of valve and measured the area avg of Total pressure and static pressure using function calculator....value of Total pressure is less than static pressure...how is it possible?...what can be the possible error. |
October 24, 2016, 06:03 |
Rep Power: 143 |
1: Maybe, maybe not. It depends on the simulation, there is no general rule. (If it was a general rule, wouldn't it be the default convergence criteria?)
2: This is unlikely to be a problem. As long as the linear solver converges and your residuals are going down you are likely to be OK. 3: I cannot explain this. |
compressible flow calculation error using rhoSimpleFoam solver | student4326 | OpenFOAM Running, Solving & CFD | 7 | November 2, 2015 11:34 |
Gate valve flow simulations... | nikesh | FloEFD, FloWorks & FloTHERM | 5 | January 28, 2014 01:31 |
High Speed multi phase flow | jonita Macyte | Main CFD Forum | 0 | March 19, 2010 06:46 |
High speed flow problems | Sawa | FLUENT | 3 | January 14, 2003 01:10 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
