November 8, 2016, 03:09 |
Rotating plane in CFD-Post
david
Rep Power: 13 |
I am currently doing some post-processing of a rotating blade in CFD-Post. I am interested in looking at the pressure distribution along a polyline ( i created this using the intersection method between a plane and the surface of the blade). For a stationary case, this is fine. But I have a transient case where the blade is constantly rotating. Is there a way in CFD-Post to make the polyline rotate with every timestep? Many thanks in advance. Cheers |
November 9, 2016, 08:24 |
Rep Power: 12 |
Your poly line is generated using the intersection method between a plane and the surface of the blade, so it rotates with the blade. one way is that, export the coordinates of the poly line and again import those to CFX post and define a new poly line. it just came to my mind I am not sure if it helps. (can be tried) |
November 21, 2016, 11:32 |
david
Rep Power: 13 |
Hi ali,
It didn't work. |
CFD post - Creating moving plane | hossein_sml | ANSYS | 0 | October 30, 2016 04:06 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
How to visualize Output Equation Residuals in CFD Post | rubin4ik | CFX | 2 | June 22, 2011 06:37 |
