additional equation for heat transport
Old   December 16, 1999, 08:42
Default additional equation for heat transport
Sascha Becker
how can I define/implement an additional equation for the heat transport due to conduction e.g. the flow through a porous media with heat transport inside the media.
Thanx
Sasa
Old   December 20, 1999, 01:36
Default Re: additional equation for heat transport
Duane Baker
Hi Sasa,
in \CFX-TASCflow you define the region in tascbob as a Conjugate Heat Transfer (CHT) porous region. This gives a volume averaged temperature for each of the fluid fraction and the porous solid (conduction) fraction.
It is often necessary to add some terms due to the loss of detailed information due to the volume averaging process. This is much like the information loss and closure required when we move from a molecular view of transport to the continuum approach or the Reynolds averaging approach for turbulence.
Regards, Duane
Old   December 20, 1999, 02:58
Jan Rusås
Hi Sasa,
If you are using CFX4.2or3 then you could use the usrsrc.f. Calculate the sources terms (heat) due to solid conduction and return it to the flow solver.
Regards Jan
Solving Transport equation for additional variable using CFX creddy_trddc CFX 11 April 2, 2015 21:07
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
Transport equation for an Additional Variable HariBol CFX 2 November 26, 2007 16:07
Additional Variable - Diffusive Transport Equation RadheShyam Das CFX 3 October 18, 2007 12:35
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
