cylindrical coordinates
Old   October 30, 2000, 05:24
Default cylindrical coordinates
A.Schulze
Hi, how can I transform the calculated x,y,z velocities into radial, tangenial and axial velocities under CFX5.4visualize?
Thank You
Andreas
Old   November 1, 2000, 23:41
Default Re: cylindrical coordinates
joecfd
There is no quantitative calculation available in visualise to do this. You will have to use the user export features to write the velocity fields to a file and then perform the transformation yourself.
Old   November 7, 2000, 19:49
Dan Williams
Actually joecfd is wrong. When you have properly setup an RFR problem the radial, tangential and axial velocities are available on the vector plot form, at the bottom in the little selection box. There are several different options there.
Dan.
Finite Volume Method For Cylindrical Coordinates falopsy Main CFD Forum 45 August 14, 2023 21:14
working in cylindrical coordinates in fluent Randheer Yadav FLUENT 2 January 18, 2015 16:25
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
Cylindrical coordinates ? T.D. OpenFOAM Running, Solving & CFD 17 September 26, 2010 15:37
Calculation in cylindrical coordinates Franz Wingelhofer CFX 0 December 28, 1999 07:46
