two types of coal combustion
Old   November 14, 2000, 06:00
Default two types of coal combustion
yang zhenya
Does anyone know how to simulate two types of pulveried coal combustion in a furnace? They come into the furnace from different inlets.I appreciate your help very much.
Old   November 24, 2000, 14:41
Default Re: two types of coal combustion
Judy Cooper
Hello Yang:
Which CFX software are you using ?
The CFX-Tascflow software from AEA Technology can do this with as many coal inlets as you would like. Pulverized coals are defined as Lagrangian particles that devolatilize and burn as they travel through the combustor.
The coal devolatilization period is described by a vaporization curve for the volatiles. Different coal properties can be entered as percent volatiles and char fraction to simulate higher or lower rank coals. Char and volatiles burn and the particle mass is reduced accordingly. Volatile combustion chemistry can be defined using Arrhenius kinetics, flamelet mechanisms or simple eddy dissipation (mixed-is-burnt) models. Information on chemical species, flow dynamics, coal particle sizes and coal particle trajectories is available from the post-processor.
If you are interested in learning more about the CFX Tascflow software, contact Paul MacDonald at AEA Technology. His email is paulmac@asc.on.ca, phone (519) 886-8435 x 288
Hope this helps,
Judy
Old   November 26, 2000, 21:48
yang zhenya
Hi,Judy I am using CFX4.3 now,anyway,Thank you for the help.
Old   November 28, 2000, 07:55
Jan Rusås
Hi Yang,
I imagine that you can use the USRPBC routine, where you can specify the massfraction of ash, volatiles etc. for each particle track on different patches. Hope it helps Regards Jan
Old   December 3, 2000, 23:38
yang zhenya
Thank you very much.Jan
Old   December 12, 2000, 07:56
Default I am a beginner!!!
fengwei
Hello! EVERY ONE ! I AM A NEW USER OF CFX4 AND CFX5, BUT I don't know how to start my work with these software. How can I do first???
Old   December 13, 2000, 06:49
Default Re: I am a beginner!!!
Gert-Jan van der Gulik
Try the manual that is on your desk on your right hand side. Or maybe it is on your left hand side but you have to check that. I can't see it from here.
Old   December 13, 2000, 13:33
John C. Chien
(1). Well, I really like your answer. (2). I think, he is new to the code. He is not yet a new user. (3). If that's the case, he might not have the set of manuals at all. (4). It would be helpful to sign up the beginner's class first. Contact the vendor to see if they provide such training in your city.
Old   December 16, 2000, 19:15
fengwei
I am happy to see your answer!!! I am doing as what you'v said. In fact,I come to use the cfx(4 and 5)only for three month ,and I get the manual from others recently(last Friday).This is the second time that I come to the cfx forum,and I want to be a new number of yours. thanks!!
Old   December 20, 2000, 00:57
Dan Williams
CFX-5 is pretty straightforward to use. What exactly are you trying to do? I'd suggest doing all the tutorials in CFX-5 to get a feel for how it works. The user documentation comes "on-line" with the software. You can get at it from the launcher.
Old   December 21, 2000, 08:09
  #11
dinesh
Sir, i want to know about the upwind sheme.(what is the significance)
Here i have my second query: If i want to code for a rotating machinery,how to incorporate the stationary frame with rotating frame.(EG: Pbm related to the cavitation in a hydraulic turbine...here we've the rotating component as turbine runner and the stationary component as the inlet of the turbine) pls do me favour. thank you
Old   December 21, 2000, 08:13
Default reg:rotatiing frame of reference
  #12
dinesh
Old   December 23, 2000, 03:20
Default Re: reg:rotatiing frame of reference
  #13
O'
pls check the CFX manul. The example "TPP-Unsteady simmulation of a Francis Runner flow"may be helpful.
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 09:39
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 23, 2010 23:56
Coal combustion and ash reaction kinetics sega Fluent UDF and Scheme Programming 0 January 21, 2010 08:05
moisture in coal combustion Sheng FLUENT 3 June 15, 2003 19:43
Coal combustion with Fluent 4.5 or 5.0! Sriram Popuri Main CFD Forum 2 July 24, 1999 11:34
