Can I define grids motion as a time functions
Old   March 28, 2001, 06:22
Default Can I define grids motion as a time functions
Darcy
Dear all
The complete title is 'Can I define grids motion as a time functions in a command file?'
In CFX-4, I think it not a easy job to use USRGRD for the definition of grids motion. I saw the desk calculator mode in command file today.I wondered if it can help me define grids motion to be a time function immediately in command file. To give my comcept, I give the commmand file codes below:
>>GRID MOTION PARAMETERS
#CALC
ALPHA = OMEGAT ** 2.0 / (4.0 * 3.41592);
OMEGA = ALPHA * TIME;
#ENDCALC
/* THE VARIABLE 'TIME' IS TIME VALUE OF TRANSIENT FLOW FIELD */
BLOCK NAMES 'BLOCK-NUMBER-1','BLOCK-NUMBER-2'
POSITION OF MATION AXIS 3 * 0.0
DIRCETION VECTOR OF MOTION AXIS -1.0 0.0 0.0
ROTATION SPEED #OMEGA
>>END
I make grids 'BLOCK-NUMBER-1' and 'BLOCK-NUMBER-2' rotate about the axis defined by (0,0,0) and (-1,0,0). The rotation speed is a linear time function. The rotation speed is 0 at t = 0 and OMEGAT when t = T. What's more the rotation acceleration is constant.
Is it all right? If it's not, pls. tell me what is not correct. Thx.
P.s. Is there someone tell me how to use CALL DEF('.spch.') and CALL DEF('.indc.')
Old   March 28, 2001, 16:01
Default Re: Can I define grids motion as a time functions
gjvdg
Darcy,
- My calculator says pi is equal to 3.141592654 and not 3.41592.
I used the following code for rotation of block1 and 2 with
- 3 Hz;
- 360 degrees in 56 steps
- total number of steps is Nstep = 672
- This makes 672/56=12 rotations
- 12 rotations at 3 Hz is 4 seconds in the real world.
#CALC
PI = 4.0*ATAN(1.0);
DEGREE = PI/180.0;
FREQ = 3.0;
OMEGA = 2.0 * PI * FREQ; /* rad/s */
ANGLE = 360/56;
RSTEP = ANGLE * DEGREE;
DT = RSTEP /((2.0*PI) * FREQ);
NSTAP = 672;
#ENDCALC
MOTION AROUND X AXIS
BLOCK NAMES 'BLOCK1' 'BLOCK2'
>>TRANSIENT PARAMETERS
:>FIXED TIME STEPPING
TIME STEPS #NSTAP * #DT
Hope this helps, Gert-Jan
Old   March 29, 2001, 01:47
Darcy
Thank you, Gert-Jan
I forgot use atan() to determine pi and typed it by hands in command file.
Additionally I gave a wrong title. This time I give a new title as 'Can I define the speed of grid motion as a time function in command file'
I tried yesterday and failed to archive my goal. I hope somebody can tell me if it is possible.
Darcy
Old   March 29, 2001, 08:34
Gert-Jan van der Gulik
Darcy,
I think it is not possible to vary the speed in the command file. You have to do this in USRGRD which is not too difficult, depending on your geometry, but you have to invest some time in it.
Gert-Jan
Old   March 29, 2001, 21:14
Darcy
Yes, I think so.
Thank u.
Darcy
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 15:15
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
