cfx5 visualise
Old   September 20, 2001, 23:58
Default cfx5 visualise
nick
hi, I have simulated an axial pump under cfx5. When I visualise the results I cannot see some part of the geometry that I have drawn under cfx build. Cfx visualise recognise that it is there we do not see it. If I am clear enough, does anyone know how to change the view of the geometry in cfx visualise? Thanks for your help. Nick
Old   September 26, 2001, 14:32
Default Re: cfx5 visualise
joseph
hi nick
this is easy man. go to plots- then set "action" to modify there below you will see Outlineplot click on it and then below it you will see "edge angle" move it the right or left till you are able to view the the full figure.
try it and it will work.
joseph.
Old   October 1, 2001, 12:14
Default EASY
gilberto
Easy mate, you go to PLOTS-MODIFY, and you select OUTLINEPLOT,and u move the edge angle,you will see your drawing. The only problem is you are going to see the mesh as well, I mean, you dont get to see the drawing exactly as you drew it in CFXBuild. Well, just play with that edge angle, and check it out for yourself.
Linking between my own code and CFX5 in Windows Se-Hee CFX 2 May 17, 2007 08:52
How can I visualise a particle cloud Sandra FLUENT 0 May 23, 2006 05:41
CFX5 dump file format? Eric Pellissier CFX 1 April 6, 2006 14:15
CFX5 and user FORTRAN Worth CFX 9 December 25, 2003 01:43
Thin Walls in CFX5 Dave Hargreaves Main CFD Forum 1 April 14, 1999 12:08
