TASCflow,problem with script and parallel mode
Old   October 2, 2001, 07:30
Default TASCflow,problem with script and parallel mode
Zbynek Hrncir
Hi everyone, I want to launch tascflow3d in parallel mode by way of the script ,but I always receive error massage
-------------------------------------------------------------------------------------- Parallel process summary information:
__________________________________________________ __________________________ Slave number 1 (Process 2)
Could not start: tascflow3d -par -nr 12127936 -ni 2022150 -nd 6482 -nc 73 -nl 31
Execution terminated by routine SPWSLP.
STOP due to error : Slave Process Terminated --------------------------------------------------------------------------------------
The script contains only "tascflow3d -par2" When I use in the script single CPU mode or when I launch tascflow3d in parallel mode from command line everything is ok. Would you please give me some suggestions where may be problem. I use CFX-TASCflow3d 2.10.0-25 and IRIX 6.5
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
batch mode - parallel run turbotel CFX 2 March 29, 2011 16:53
Perl script for intialisation pratik mehta CFX 2 September 10, 2008 03:09
Help: how to realize UDF on parallel cluster? Haoyin FLUENT 1 August 6, 2007 13:53
