Shear stress induced on fluid in centrifugal pump |
October 8, 2012, 21:31 |
Kimberley
Im completing a study on an artificial heart pump. I have completed a CFD model in CFX, however i am confused as to how to determine the shear stress induced on the blood. Predefined expressions gives Wall Shear Stress, but i dont think this is what i need. Do i need to define my own expression? And does TauZY = viscosity * (dv/dz + dw/dy) be the correct expression for shear stress on the fluid? Any insight much appreciated |
September 30, 2016, 02:20 |
kastarkas
Rep Power: 9 |
Its alomost 4 years old..but still ...i hope you might have solved the problem and travelled way beyond that...
September 30, 2016, 11:39 |
Rep Power: 32 |
In CFD-Post, you can create user defined variables, and write expressions for the different components of the stress tensor, say: sigma_xx, tau_xy, ...
Keep in mind CFD-Post provides the gradient of the velocity field, and you can use them as in Velocity u.Gradient X (du/dx). Also, to clarify the confusion between Wall Shear Stress and tau_yz. Wall Shear Stress is the tangential force per unit area on the surface, i.e. the tangential component of the product between the stress tensor and the normal unit vector. tau_yz is the component in yz plane of the stress tensor which only defines the state of stress in space, and a surface must be defined to compute the force per unit area on such surface. For more information, https://en.wikipedia.org/wiki/Stress_(mechanics) Hope the above helps, |
blood pump, cfd, cfx, pump, shear stress |
Autoblade centrifugal pump template | mahdi balali | Fidelity CFD | 3 | February 18, 2014 08:56 |
Centrifugal Pump Cavitation problem or not. | ismael.s | CFX | 13 | February 27, 2012 08:00 |
excess shear stress in Flow3D | ETHACuch1 | FLOW-3D | 1 | January 14, 2011 15:52 |
LES: mean wall shear stress | Francois | FLUENT | 0 | July 7, 2005 11:15 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
