CFX For two phrase flow
Old   October 15, 2001, 04:19
Default CFX For two phrase flow
windhair
Someone know about the two phrase flow capibilities in CFX? Comparing Fluent or CFX, which one suit to simulate the mixture and chemical reaction?
Thanks.
Old   October 19, 2001, 16:17
Default Re: CFX For two phrase flow
Ribeiro
Man, I couldn't tell you what is the best. But I can say that it is possible to do in CFX. The problem is the coupling between the chemistry and multiphase. If you get the insight you get the right results.
Regards
Old   October 22, 2001, 03:54
Herve
CFX has been known for its strength in multiphase and chemistry for a while. There have been postings earlier abount CFX vs. other codes (Star-CD in particular). In CFX-4.4 moreover you have not only a large panel of models which are pre-available, but you can also code yourself quite a lot more. As Ribeiro said, what is often more importatnt is to get the set up (i.e. understand how to model the reaction) right. In CFX-5.5 a lot more model are being added and the sover is fully coupled which makes simulation even more robust.
courant number for transient flow on CFX ? amine CFX 13 August 20, 2013 19:02
[HELP] Slip flow boundary condtion in CFX jeffwmb CFX 20 March 13, 2013 16:21
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 07:08
turbulence model in CFX, seperated flow F. Bhuiyan CFX 3 August 9, 2009 23:28
demo free flow blunt body in cfx ansys 11 jan CFX 1 July 31, 2007 19:44
