December 4, 2001, 02:58 |
Non-Newtonian Fluid simulations
Hi everyone
How d'you insert properties for Non-newtonian fluid in turbulent flow. I'm a new CFX user. Thanks |
December 4, 2001, 22:25 |
Re: Non-Newtonian Fluid simulations
Hi JMM,
Just enter an expression for the relevant property. For example, if you want to make viscosity a function of shear rate, you would replace the value for shear stress in the fluid properties with an expression, myViscosity, where: myViscosity = K*sstrnr^(n-1) Where K has units of [Pa s^-1], sstrnr is the shear strain rate provided by the solver, and n is a dimensionless constant. You may also want to put upper and lower bounds on the shear strain rate to keep the results physical during convergence. There is a Non-Newtonian fluid tutorial which describes all this quite nicely. Regards, Robin |
December 5, 2001, 05:31 |
Thanks Robin I'll take it into consideration.
Else, this is to be used for stirred vessels. I've eared Promixus does not give accurate way to draw an impeller. Is there any way to deal with non-standard impeller shape? JMM |
December 5, 2001, 19:40 |
JMM,
I was assuming you are using CFX-5. If you are using Pro-Mixus, I'm not sure how you would do the same. In the future, please indicate what product you are referring to in your post. Regards, Robin |
applications of laminar newtonian fluid past a bluff body | swamysrikanth | FLUENT | 0 | December 15, 2009 01:51 |
error using combination of step function | xujjun | CFX | 1 | January 15, 2008 16:46 |
What is the total energy for incompressible fluid? | Harry Dong | Main CFD Forum | 12 | February 4, 2006 00:55 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
