Mass balance
Old   March 20, 2002, 01:40
Default Mass balance
Sumon
Hi everyone
I have a problem with the mass balance.
It is multi-phase (three phases) model. There are two inlets.
Inlet1: Only phase 1 Inlet2: Phase 2 and Phase 3 (0.9 and 0.1 volume fraction respectively)
Outlet is as pressure boundary. Ambient conditions and initial guess are set (vol. fraction of phase 2 is almost 1.0).
K-eps turbulence model is used and the inlet boundary conditions are set with proper parameters.
But the mass flow rate through the pressure boundary flactuate with the number of iterations.
It is very difficult to converge 3 orders. At the moment it converge near about 3 orders.
But I don't know why the mass is flactuating through the pressure boundary.
Could any one help me on this regard. Any suggestion or tips will appreciate.
Regards
Sumon
Old   March 20, 2002, 16:41
Default Re: Mass balance
Astrid
Whatprogram do you use? CFX 5.5, 4.4 or Tascflow?
Astrid
Old   March 20, 2002, 18:27
Sumon
Hi Astrid
I am using CFX 4.3 for multi phase flow at the moment. Mass should be balance in inlets and pressure boundaries. But I have still problems.
Regards
Sumon
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 16:36
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
mass balance of single species antonietta FLUENT 0 November 11, 2005 11:11
Mass balance problem! JADG FLUENT 4 December 27, 2003 10:40
