How much does a skewed element effect a solution ? |
April 5, 2002, 09:44 |
HI
How much does a skewed hexahedral element effect a solution in CFX 5.5 ?(structured grid),especially in a MFR problem what is the least angle recomended by CFX 5.5. from 0-90 deg? thanks joseph |
April 5, 2002, 23:43 |
Re: How much does a skewed element effect a soluti
CFX-5 can handle fairly bad skew angles, say >10-20 deg. The quality of the solution is going to rely mainly on how many you have. If 50% of your elements are skewed, then your going to have a tough time, and you will probably get a bad answer. If 5% are skewed, then you might be OK.
Neale |
April 7, 2002, 17:10 |
It depends a lot on where the cells are, i.e. in the far-field where the flow is roughly constant the solver will have little problem with highly skewed cells. However in the boundary layer or in the vicinity of a shock you should have orthogonal cells.
The best way to check if skewed cells are degrading the solution is to perform a grid convergence test - i.e. double the grid resolution and see if the results change. You should also plot the residuals in post and see if the largest residuals are in the highly skewed cells. |
April 8, 2002, 00:21 |
thank you steve and Neale
hi,
thanks for your valuable comments. Joseph |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Does FOAM converge to exact solution in Laplace equation? | santiagomarquezd | OpenFOAM Running, Solving & CFD | 0 | March 26, 2010 07:52 |
Effect of Grids on Solution | Andrea | Main CFD Forum | 6 | May 13, 2007 21:34 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
