Meshing error
Old   June 8, 2002, 07:31
Default Meshing error
Peter
Hi I have imported a iges file into mesh only mode. But when I try to mesh I get the following error:
Fatal Error: Face evaluation failed
Error: ------
face evaluation failed error status code: 2 Surface 2187
Does anyone have an idea ???
Thanx.
regards
Peter
Old   June 10, 2002, 07:08
Default Re: Meshing error
henry
hi
there is one way to eliminate this,use the parasolid otion while exporting ,and if you are not able to do this then while expoting to iges check on the tolerance and then try to increase it by a tenth,
but I'd say parasolid is any day a better choice.
henry
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
