June 10, 2002, 00:56 |
a grid error during solving process
Hi everyone:
The problem is about the simulation of a external-loop airlift reactor. I have obtained the geo file by build. But a error occurs when reading the grid in solving process. The error massege is like this: ERROR SPECIFYING GRID IN BLOCK BLOCK-NUMBER-1 THE CELL VOLUME CHANGES SIGN THE VOLUME CHANGES SIGN AT CONTROL VOLUME ( 1, 1, 1) THE VOLUME CHANGES SIGN AT CONTROL VOLUME ( 6, 4, 15) THE VOLUME CHANGES SIGN AT CONTROL VOLUME ( 8, 4, 15) MAXIMUM VOLUME = 0.4969E-12 MINIMUM VOLUME = -.9555E-04 ***> ERROR NUMBER 1 IN FRONTEND PROCESSING Could you tell me how can i correct this error? Thanks a lot in advance. |
June 11, 2002, 17:54 |
Re: a grid error during solving process
It looks like you have somewhere elements with negative volumes. Try to read the geometry in Analyse or Visualise (or View) to find out where your elements do not match the geometry. Then create a new geometry in Build.
Astrid |
June 14, 2002, 10:07 |
I think you might have picked the points on Block no. 1 in the wrong order when you made it. Make sure you pick them in an orderly fashion face by face. All the best.
James |
Display Modes | |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
Compressible Nozzle Flow | sebastian | OpenFOAM Running, Solving & CFD | 14 | September 21, 2016 11:47 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 10:20 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 04:32 |
