How to make data file for matlab from CFX?
Old   July 18, 2002, 16:18
Default How to make data file for matlab from CFX?
cfxbeginner
Everyone: I want to draw 3d picture by matlab. But the data file (containing the velocity and pressure of a certain plane)I got from the result of CFX5 by "export" command is not fit to matlab.The data is not in order.For example, if x=0,y should be 0,2,4,6,8,10,12, x=2, y should be 0,2,3,4,6,8,10,12.But the data file is not in such way.For example, when x=0 y=0,2,4,6,8,10,12; when x=2,y=2,6,12(some positions have no data be exported).So I cannot draw satisfied picture from such data file by matlab. I think it is because the mesh of CFX5 is unstructured grid.How to resolve it? I have fieldview, it can export data of a certain plane by "export" command.But the file made by fieldview has the same problem. How to resolve this problem? Thank you!
Old   July 22, 2002, 12:13
Default Re: How to make data file for matlab from CFX?
Tommaso
Probably you can use keyword GRID CENTRES in
:>PRINT OPTIONS
:>WHAT
Old   July 24, 2002, 16:59
Robin
Read your data into a spreadsheet application and reorder it.
Robin
Old   August 15, 2002, 09:34
René
What I do is to first "re-map" the data from CFX 5 onto a structured mesh. I use the MATLAB comands delaunay, tsearch and dsearch to interpolate the raw data onto my custom defined structured grid. Then go wild with the data analysis....
René
Old   October 19, 2002, 07:56
DingEnbao
firstly check your output data. try command griddata in matlab.
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
File export from CFX 5.3 Sinjae Hyun CFX 1 July 12, 2000 09:20
