Convergence
Old   July 22, 2002, 08:23
Default Convergence
Mohaba
hey guys
I am modeling a ventilated space. when I increase the number of cells the mass residual decreases only in an order of one. Is it possible to reduce it further? For a course grid I get a reduction of order 12, when I triple the grid size there is a problem.
Thanks
MK
Old   July 23, 2002, 13:25
Default Re: Convergence
James Date
Just a little tip. Check that the Y+ of any cells near any solid walls is greater than 11, usually cell sizes should be such that the Y+ is in the range of 30 - 500. I have found in my research that failure to stick to the correct bounds for Y+ can result in lack of convergence and very long solution times.
Good luck
James
Old   July 29, 2002, 05:32
Mohaba
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
