Turn off velocity Equations
Old   August 1, 2002, 07:10
Default Turn off velocity Equations
Nelson
Dear all,
I want to seek a suggestion to turn off the velocity equations, i.e. fixed U, V, W, for the Solver run. Anyone can help me? Thank you.
Nelson
Old   August 1, 2002, 10:06
Default Re: Turn off velocity Equations
cfd guy
Which solver are you using?
In CFX-5 you can set fluids = f in the expert parameters.
In TASCflow, in the PRM file: fluids = f; turbmd = f; tmptre = f will turn of the fluids, turbulence and energy equations respectively.
In CFX-4, I don't know how to do it.
Regards, cfd guy
Old   August 2, 2002, 03:48
Sergei
Hi, excuse my ignorance please.I would like to know when & why it is suitable to turn off these eqs?
Old   August 2, 2002, 05:08
Astrid
I can be helpfull if you want to calculate different temperatures or (passive) scalars distributions at a given flow field. Provided they do not disturb your flow field, that's what you assume..
Astrid
Old   August 2, 2002, 05:11
Astrid
In CFX 4 you can turn off UVW and p with the keyword:
ITERATIONS OF HYDRODYNAMIC EQUATIONS 0
in the subject: >>SOLVER DATA >>PROGRAM CONTROL
Astrid
Old   August 2, 2002, 06:07
Default Thank you ,Astrid
Sergei
Old   August 2, 2002, 08:48
cfd guy
I use to turn off all equations (turbulence, fluids and energy) when I'm testing a new moving grid with the TASCFlow code.
Old   August 2, 2002, 18:09
Jan Rusås
I very often use this approach when dealing with combustion or heat transfer problems. I have noticed in such problems that the velocity and pressure field might have converged or does not change anymore but the residuals for the temperature/enthalpy is still decreasing. It can take very long time, many iterations, for settling the solution for the temperaure, solving the velocity and pressure just increase the computational time. So I normally get a converged solution on the velocities and then do a restart without solving the velocities. I have found this to be very efficient.
Old   September 20, 2002, 06:16
Drona
When you put fluids = f in tascflow, the momentum as well as continuity equations are turned off. Is it possible to just turn of momentum or continuity equation selectively, or even better, u-, v-, or w- componets of momentum equations separately? I normally get mass converged very quickly but one particular momentum equations (W in my case as the main flow direction is Z) takes time to solve.
Thanks
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
Results of CFX Simulations Sof_70_Usthb CFX 3 July 9, 2011 06:15
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
