Help please:Inlet Boundary Conditions!!!
Old   October 30, 2002, 21:22
Default Help please:Inlet Boundary Conditions!!!
David
Hi CFX users,
I want to specify pressure and mass flow rate at the same time on inlet of a pipe. Is it possible? For example, 15atm and 1.6e-004kg s^-1. Thanks in advance.
David
Old   October 31, 2002, 02:51
Default Re: Help please:Inlet Boundary Conditions!!!
Fabian
Are you simulating compressible or incompressible flow? In incompressible the absolute value of pressure is of no relevance as only pressure-gradients appear in the equations.
Old   October 31, 2002, 08:56
David
Thanks, Fabian. I am simulating two-phase flow, one phase is gas and the other is liquid.
Old   October 31, 2002, 10:30
Robin
Hi David,
It is not possible to define both pressure AND mass flow at an inlet (unless it is a supersonic inlet, it which case it is necessary), nor does it make sense to do so. You will need to specify a pressure boundary condition elsewhere in your simulation (either another inlet, an outlet, or an opening). The pressure field will then be determined based on momentum and continuity.
Regards, Robin
Old   October 31, 2002, 19:03
David
Hello Robin
Thank you very much for your answer. Now I understand it.
Many regards David
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
Boundary conditions for 2D Navie-Stockes simulation L1011 OpenFOAM 5 December 13, 2012 08:17
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
