December 2, 2002, 09:29 |
Turbulent Schmidt number
Does anyone know if it is possible to manually set the turbulent Schmidt number that is used in CFX 5 for the calculation of mixing of different species? Thank you. Regards, Cujo |
December 2, 2002, 12:17 |
Re: Turbulent Schmidt number
Yes. It is one expert parameter. Check this with your CFX support.
December 2, 2002, 19:28 |
Use the expert parameter:
turbulent schmidt number = X You will have to do this manually, I don't think it is available in the defintion file editor. Neale. |
Low Reynolds number k-E Turbulent Model | Sohail | FLUENT | 19 | July 16, 2020 14:08 |
Turbulent Schmidt Number | John | FLUENT | 8 | June 1, 2015 05:04 |
Problem with decomposePar tool | vinz | OpenFOAM Pre-Processing | 18 | January 26, 2011 02:17 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Question on Schmidt number | ap | Main CFD Forum | 0 | March 26, 2008 18:58 |
