December 13, 2002, 08:22 |
Grid
I would like to extract grid data from CFX-5 definition file. Is it possible? If yes, how?
KG |
December 13, 2002, 10:02 |
Re: Grid
Check ou the export modes in the solver manager (do a F1 there).
December 13, 2002, 12:30 |
Re: Grid
read about user mesh export in the documentation. There is a library you can use to do this.
Neale |
December 16, 2002, 00:06 |
Re: Grid
In the cfx5.5.1 solver manager p.no 141 you can find the various options used to export the mesh from cfx to some other solver .
you can do this by the following manner. Go to solver manager in that, select tools in that select export.then the export form will open. you can select the type and output level you want and click export.Then you can fine the exported mesh file in the same directory with the extension of your export type ex .cgns,.patran like that. |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 13:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 16:43 |
