Setting momentum source for periodic calculation
Old   October 26, 2002, 12:39
Default Setting momentum source for periodic calculation
lego
Hi!
I would like to investigate fully developped flow through a pipe bundle. I would like to perform it by using periodic boundary condition, but I now the mass flow, not the pressure drop. How to set the momentum source [Pa/m]?
Old   October 26, 2002, 18:59
Default Re: Setting momentum source for periodic calculati
Robin
Iteratively!
Old   December 16, 2002, 13:45
Swapnil
Hi Robin,
What do you mean by saying iteratively? Will you please explain in little bit detail.
Thanks, Swapnil
Old   December 16, 2002, 17:02
Robin
The momentum source will allow you to specify the pressure drop. However, to match the mass flow you will have to set your momentum source, check the mass flow you get, then tweak the momentum source until you get the mass flow you want.
Robin
Momentum source coefficient, cylindrical coordinates, circumferential component? polakse CFX 15 January 18, 2016 02:40
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Pressure jump and momentum source Tanya FLUENT 1 June 4, 2009 15:22
Mass transport, momentum source and turb K.E CFDtoy FLUENT 0 April 24, 2006 00:33
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
