February 24, 2003, 15:17 |
Streamlines
Hi to everybody!!! I need to get the max and min value of a variable over a streamline in the CFX-Post (V 5.5.1). I already tried with the post-calculator and creating charts. The first one did not work because the "locators" available to calculate maxvalue and minvalue were boundaries, surfaces and points only (not lines). The second one was very inaccurate because is a visual estimate of the value. I really need the exact numbers.... Thanks in advanced!
Claudia |
February 24, 2003, 17:11 |
Re: Streamlines
Hi Claudia,
You can export the streamline data to a file and examine it in a spreadsheet or other application. Regards, Robin |
February 25, 2003, 15:32 |
Re: Streamlines
Hi Robin! Can you please give me more details about how can I do that? Take care,
Claudia |
February 26, 2003, 13:13 |
Re: Streamlines
Hello Claudia,
the easiest way to get the min/max values is to set the color range to "local" in the "Streamline" window. Then in that same window the Min/Max-values are displayed. Greetings, Chris |
[CFD Post] Surface streamlines not located where needed | siw | CFX | 1 | July 7, 2011 19:13 |
How to get Streamlines to interact.? | stephen__white | CFX | 2 | April 12, 2011 17:00 |
Streamlines under Moving reference frame; Spiral streamline from Tecplot | aiqch | Tecplot | 2 | October 29, 2009 23:27 |
Custom streamlines - only 2 velocity components | bernarde | STAR-CCM+ | 5 | August 24, 2009 07:18 |
STAR-CD, moving grid and streamlines | Mohamed GUEROUACHE | Main CFD Forum | 1 | September 13, 1999 13:33 |
