Any weakness or limits of CFX for secondary flows
Old   March 7, 2003, 13:41
Default Any weakness or limits of CFX for secondary flows
J.T.
Any one has the epxerience of running the turbulent secondary flows by using CFX? Thanks
Old   March 9, 2003, 16:11
Default Re: Any weakness or limits of CFX for secondary fl
Hi JT,
I think you'll find that CFX5 is actually one of the best commercial codes around for solving things like secondary flows. It is simulations like that where the the coupled solver in CFX5 really shows its strength over the usual uncoupled technique.
If you are talking about CFX4, well it can solve these types of flows but the simulation time will probably be considerably longer due to its use of the uncoupled solver.
Depending on exactly what turbulent secondary flow you are talking about, you may require the Reynolds stress model to simulate it. CFX 4 and 5 both have a number of Reynolds stress models available. The new CFX 5.6 beta version also contains a stress-omega model which I am yet to try out, but looks interesting for low Reynolds number secondary flows.
Old   March 12, 2003, 18:39
J.T.
Thank you very much for the infomation! I looked into CFDesign, their results for backward facing step for 3-D turbulent flows are not very good. I am trying to use CFX. Is that easy to get started if you got a pretty complicate geometries? In other word, is their mesh generation automatic or user-friendly? How do you like their post-processor?
Thanks!
Old   March 12, 2003, 21:21
Peter
The automatic mesh generation in CFX5 still needs a lot of improvement. If your geometry consists of the curved surface or fillet, then you may find that the mesh elements will tend to squish together at this region when you use CFX5 mesh generator. The louisy mesh may destroy the whole solution depending on what problems you have. What I suggest to you is to try importing your mesh from other mesh generation software and solve your problem in CFX5. It does have some excellent solvers anyway.
Old   March 13, 2003, 13:11
J.T.
Hi, Peter Did you check their benchmark test with turbulent flow over a 3-D lid-driven cavity? I will ask them to provide the tested results. Since ANSYS bought the CFX, do you think ANSYS's mesh generation will provide best results? If I got the answers I will discuss with you. Thanks!
Old   March 16, 2003, 09:52
Robin
Hi Peter,
Bunching such as this can easily be fixed by setting proper mesh controls.
Robin
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
CFX 5 turbulence benchmark Bart Prast CFX 16 April 5, 2002 02:55
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
CFD Short Course & CFX User Day Chris Reeves CFX 0 September 11, 2000 08:53
