mixed subsonic/supersonic flow at an inlet BC
Old   March 11, 2003, 04:33
Default mixed subsonic/supersonic flow at an inlet BC
sascha
Hello all,
what is the best and physical correct way to define the inlet BC for mixed subsonic/supersonic flow ? Currently I use a total pressure profile at this location but it seems to be physically insufficient.
ThanX Sascha
Old   March 26, 2003, 05:07
Default Re: mixed subsonic/supersonic flow at an inlet BC
N Menon
this seems to be a bit of an obvious answer, and im sure u must have tried it. But do i know where in your inlet boundary the transition from supersonic to subsonic occurs, if so, then u could used two inlet boundaries with one subsonic and one supersonic?
Old   March 26, 2003, 11:45
sascha
we tried this and the results are not physical correct because of the interface between the two parts. They have no physical velocity profile.
So I am still looking for a good answer. Maybe I will find it sometime.
sascha
Velocity Inlet BC -- Flow Reversal salihovic FLUENT 0 May 8, 2011 05:45
Problems modeling subsonic engine air inlet with flow separation TWaung CFX 2 March 29, 2009 18:42
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
Reversed flow in pressure inlet eric FLUENT 3 January 26, 2004 20:04
Mass flow inlet B.C. at exit... Jack Keays FLUENT 2 October 6, 2000 08:39
