Import iges file into CFX5.4.1 in Unix system
Old   May 2, 2003, 02:36
Default Import iges file into CFX5.4.1 in Unix system
yli
When I tried to import an iges file produce with Invetor6.0 in WindowXP system into CFX5.4.1 in Unix system, the following information was shown. "The specified file filename.igs is not a valid fixed(80 character) line length ASCII format" Can anyone help me? Bob, thank you for your information.
Old   May 2, 2003, 08:28
Default Re: Import iges file into CFX5.4.1 in Unix system
Holidays
What is the length of the path (should be less than 80 character)? Can the file be tared and read on Unix, or is the file corrupted after you transfered it?
PS: CFX-5 is now on 5.6 I believe (or about to be delivered); how come you are on 5.4.1?
Old   May 5, 2003, 08:49
tascflowuser
Use Hummingbird exceed3d software to transfer files from PC to UNIX platform. It will convert the files in proper format and will solve your problem.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
