invalid data range for argument?
Old   April 9, 2003, 09:45
Default invalid data range for argument?
pete
the error message; $# (PCL)Invalid data range for argument. Arg#:2
appears in my build journal file after the command to create the definition file and the comment '$# Processing remaining boundary conditions...' The solver doesn't start and no definition file is created. Has anybody encountered this problem and do they know what the error message means? Pete.
Old   April 10, 2003, 09:36
Default Re: invalid data range for argument?
Pascale Fonteijn
I have seen this when somewhere I had given a wrong number, e.g., an integer where a real is expected. Recheck all your BC's.
Pascale.
Old   April 10, 2003, 10:04
pete
I had declared a variable 'real height', say, then changed the parameter 'height' to 'height2' without changing the variable declaration so an undeclared variable appeared, don't make the same mistake!
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 07:51
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
