Axis of rotation
Old   April 29, 2003, 03:55
Default Axis of rotation
Dunga
Hi All,
I have been doing my simulation, using the MFR approach, of a mixing vessel with rotation by x axis, I did this because I experienced some problems when I attempted to set it by z axis. So far my results look qualitatively reasonable. Thus, I see the type of flow profiles that I expect for U, V, W. k and epsilon. They look very much like those in which the rotation is along z axis.
Is the axis of rotation crucial in any way??
thanks Dunga
Old   May 2, 2003, 08:37
Default Re: Axis of rotation
Holidays
In CFX-4, yes (it has to be the X axis).
In CFX-5, there is no issue as far as I know.
Old   May 7, 2003, 06:54
dunga
Hi Holiday,
Thanks for your response, Holiday. You must have realized that i took long to respond. .....My apologies. The reason is that I wanted to quote a page in the Manual, where they say that the rotation must be about the Z axis (CFX4.4), however i could not locate the page immediately.
I have been specifying my rotation about x axis, just as you have said.
regards Dunga
Old   May 7, 2003, 09:03
Holidays
I would be surprised if CFX-4 maunal said rotation was about the Z axis...
PS Is Dunga a reference to the football player? Good guy indeed...
Old   May 11, 2003, 10:44
Dunga
Hi Holiday,
I am a footballer, yes, but not related to the other Dunga.
I believe you are right that it has to be about the X axis. This is what I have been doing. I suspect that I misread something, probably the " Z CYCLES PER REVOLUTION" for the cyclic connections in the transient (SG) simulation.
regards Dunga
Specifying axis of rotation David Banks FLUENT 5 November 21, 2016 08:38
Rotation Axis in Fluent arapha FLUENT 3 November 8, 2016 21:44
Axis of rotation for centrifugal compressor Mattia FLUENT 4 October 22, 2007 11:05
Relief Plots in CFX Michael CFX 15 June 30, 2006 08:01
rotation axis? Max FLUENT 5 December 5, 2000 04:53
