June 4, 2003, 05:35 |
Multiblock model
Hello Friends
I am using CFX 4.3, and modeling ventilated instalation. The geaometry is simple, and constructed by Build using the Multi block approach, consisting of 9 blocks. when I see the result with analyse, visualisation is possible only block by block, do you think there is some kind of wall between the blocks? how can I get one block instead of 9, in the analysis form I chose reblock button already. have a nice day and thanks for your help cfx4.3 user |
June 4, 2003, 06:39 |
Re: Multiblock model
cfx4.3 user,
Did you try this...? Under ANALYSE go to Region manager select region of plot/wireframe etc say, (1) Region (.........) Select (2) With 'Multiple select' togled ON select your blocks. However, you need to be careful here, if the blocks are many and your memory is small, you may land into problems. You can select a few blocks at a time and see what you memory can accommodate. Did I get your question correctly?? Nyatoto |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
help for different between les model (subgrid-scale model) | liuyuxuan | FLUENT | 1 | October 2, 2009 15:25 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 10:27 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
