Combustion Model
Old   June 11, 2003, 16:31
Default Combustion Model
Carola
Hi Guys!, Iīm triying to find information about Eddy dissipation model, I been searching for papers on the web but I couldnīt find any for free!. I found just abtracts or references. Anybody can help me?
Thanks in advance,
Caro
Old   June 11, 2003, 17:40
Default Re: Combustion Model
Jan Rusås
????? Something must really have gone wrong in your search. Try Google with the search words Eddy dissipation concept
You will have readings for weeks Good luck
"Have you been banned from your library?" did you make to much noise
Old   June 12, 2003, 11:00
Carola
Hi Jan!, of course I been searching on google but I couldnīt find the ecuations which describe the base of the eddy dssipation model applied on combustion. My boss is not satisfied with the information downloaded from the web, for this reason I need to find technical bibliography or something which explain the eddy dissipation advantages and disadvantages, characteristics, how this model works?, etc.
Thanks
Carola.
P.D: I been searching in the library of the university but we have not recent information about this topic!.
Old   June 13, 2003, 05:10
prasat
refer to a book by S.N.B Murthy turbulent mixing in noreactive and reactive flows. Plenum press ,New york and london 1975 in this book there is article by dupont donaldson fom pp 131 -162. I hope it helps
Old   June 13, 2003, 05:14
prasat
Hi carola have a look here also http://hugin.aue.auc.dk/publ/hjertager2000.pdf prasat
Old   June 16, 2003, 12:52
Default Thank you soooooooo much Prasat!!!.
Carola
Liquid rocket engine non-premixed combustion model Erik FLUENT 2 November 28, 2013 14:09
Combustion Model for CAI/HCCI - AVL FIRE Patryk Main CFD Forum 0 July 24, 2009 16:43
How to model combustion with only methane stream? ligang zheng FLUENT 2 May 1, 2007 09:16
Combustion model in Diesel Engines roadracer Siemens 1 May 13, 2003 10:05
combustion model Hennie van der Westhuizen Siemens 7 February 27, 2002 02:10
