no-slip wall boundary condition
Old   June 22, 2003, 06:04
Default no-slip wall boundary condition
Atit Koonsrisuk
I specified no-slip Wall boundary condition as one of the boundary conditions for my simulation. After solving, I export the velocity value along the line from wall to the free stream. I found that the velocity at the wall is not zero. In my case, it is 0.0321 m/s. Why isn't it zero? I think this might be the value at the center of the mesh next to the wall. Then how can CFX know, when it compute, that actually the velocity is zero at the wall? Thank you.
Atit
Old   August 11, 2003, 22:57
Default Re: no-slip wall boundary condition
Marco Melo
When you are in post and you want to see velocity ther's 2 options Hybrid and Conservative (I think those are the names), you can choose these 2 options by toggle on one of them. In Hybrid you should see that the velocity is zero. I hope this will help you.
Marco
Old   July 9, 2014, 17:24
Stephen Waite
Stephen Waite is on a distinguished road
Hello, I'm having the same problem, I set a constant temperature at a no-slip wall, however when I view the temperature and velocity in CFD-post at the wall they are not the values I specified.
I can see that the "conservative" boundary data tab is selected however I'm unable to change to hybrid because the boundary data tab is shadded (i.e. you can't select it). How can I change to hybrid?
Thanks
Stephen Waite is offline   Reply With Quote
Old   July 10, 2014, 17:10
Erik
evcelica is on a distinguished road
You can only display hybrid values of pre-defined variables in CFD-POST, not used defined variables.
Like if you made a variable Mytemp = Temperature, there wouldn't be hybrid values for Mytemp, even though there are for Temperature.
Other than that, I don't know why else it wouldn't work?
evcelica is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Wall boundary condition in cylindrical co-ordinate shekharc Main CFD Forum 3 December 2, 2009 08:20
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
